I think the pistons and block are the same(I think???)
I hear the only difference is the carb??
Not absolutly sure.
The stroke might be different.
Try the Mercury techs?
The blocks are the same. BUT: While the bore and stroke are the same, the porting and compression ratio is different. A simple carb change will add some horsepower but will not get the engine to 15.
