I bought a 1979 Chrysler and it wouldn't turn on because the firing order was wrong that was fixed and I got it started, When started I noticed the water was not flowing through the engine so I turned it off took of the lower unit and inspected the pump, it had crud and it was stuck. I cleaned it out and put it back together and now it will not start, it has not spark and after investigating and researching every thing I came to find that the blue wire coming from the ignition switch (when cranking) only brings in 6.3V and during my research I found it needs more than 9.5V. I did notice that the circuit breaker keeps tripping and the blue wire after the junction block gets hot along with the CD module . I purchased a new battery and the started seems to be working fine, I am not too sure of the ignition switch or maybe the wiring. Please any pointer on troubleshooting either or both of those items, all help will be gratefully appreciated!!!!
