I have a 1996 Force 40hp recently purchased. The tach does not work and and at full power the volt meter in boat is showing almost 18 volts. I suspect rectifier problem. I would to like try the radio shack rectifier fix From reading the past forum posts I know where the 2yellow 1 red and 1 black wires attach to the radio shack rectifier. But not sure where the gray tach wire hooks up. Any ideas and does it sound like I am barking up the right tree. Not very savvy bench testing existing factory rectifier.
