Hello I am a first time boat owner so please don't mind the questions. I am mechanically able and Ive spent several hours on this forum tuning my boat. I have a 1995 quantum with a force 120 outbord motor. The problem im having is my power tilt trim will go down, but it will not raise. It has a new battery, trim motor makes a "whirring noise" when activated but will not raise, relay connections cleaned, relays tested and flipped, relays work good, power source good, Im currently replacing the oil in the Single ram power trim. "2nd question" If anybody knows how much oil I need, and what type 30wt, Iso32, ATF or tractor oil and how much. Also what could my problem be with it not raising. Is it leaking pressure somewhere, what are common known problems. Thanks in advance
