JEFF MURRAY
- Sep 4, 2013
- 14
So I had my boat out today, ran real good, after being on anchor for an hour or so, I fired up the motor, walked back to make sure the tell tale was peeing and noticed a pretty large oil slick behind the boat, after a closer look I noticed a constant stream air bubbles rising from the gear housing in the area of the front gear housing attachment bolt, after I got the boat back on the trailer I saw a stream of water soaked gear oil streaming down the gear housing from the area of that same bolt I noticed the bubbles coming from, after I returned home I tilted the motor and took a closer look only to see a small (1/8"-3/16") hole next to the bolt, I have a 1992 force 40hp parts motor also and went to look to see if it had the same hole and it does, so its there for a reason, so my questions are (1) anyone know why air bubbles and gear oil is spewing from this hole ? (2) whats the purpose of the hole ? attached you'll find a pic of the problem area. Thanks in advance for any help you can provide
