'90 90 HP Force RPM question - "sparks per revolution - degree setting" - "Tiny Tach"
My '90 90 HP Force doesn't have a built-in tach and I wanted to evaluate the RPM's for prop use and bought a small product, "Tiny Tach". This is where you wrap a wire around the spark plug wire and get small digital display.
I had to set the "degree setting", the sparks per revolution to get it to work from a variety of settings (8 sparks per revolution down to 1 spark per revolution).
Does anyone know what this should be for this outboard?
I ultimately set it to 180 degree (2 sparks per revolution) which seemed to give the closest reading. But this gave me 4,650 RPM at WOT ( about 36 mph) which seems a little on the low side, so I question the setting or the accuracy. Or does this RPM sound about right? Thanks.
