Frank Acampora
- Jan 19, 2007
- 12,004
Although this is about a prop, it is specific to Chrysler engines so I will post it here.
You know I always advocate re-hubbing props. If you have a little imagination, you can do quite a bit as far as aftermarket props for your Force or Chrysler.
This prop is an old school Oakland Johnson bronze prop made for an old OMC . I originally wanted to use it for the 50 on my 10 foot go-fast but it simply would have needed too much modification. Instead, I pressed out the hub from an old Merc 40 prop and pressed it into this prop. The rubber hub is a little too long, but too late: it is already in the prop.
This prop is now destined for use on my 1982 Chrysler twin carb, one piece lower unit, twin cylinder 60 HP. And yes, this engine will be mounted on the little 10 foot tunnel hull.
