JEFF MURRAY
- Sep 4, 2013
- 14
The issue im having is I can not get my motor to turn lock to lock in both directions, a little history, the boat was originally set up as a tiller steer, I bought the motor, I built and installed a center console, I installed a new helm, steering cable, controls etc. over the last month or so I ve purchased two different steering rods (supposably for this motor - 88 force 35 hp) ones about an inch longer than the other, they both fit but possess the same problem. I can adjust everything that can be adjusted and get the motor to full lock in either direction but not both , tonight i even temporarly extended the shaft that runs thru the steering tube by 2" with pretty much the same results. The rivers I fish are pretty narrow so a tight turning radius is a must, Iv'e worked on the issue for 3 weeks and im at the end of my rope here, anyone have any suggestions ?
