mandasboat
- Aug 29, 2013
- 11
89' Force 125
I started another thread regarding the top carb leaking fuel. As a concern, I started there, took it off and apart today. The carb is in amazing condition. I cleaned it thoroughly with carb cleaner that's safe on plastics, and compressed air. Shot through everything. The needle was seating just fine, needle in great shape, no debris residue of any sort. The float was in great shape, same deal, functional and all, gaskets showed to sign of tear or wear.
Checked all spark plugs, all new and look great, spark tested, everything is good. They are BUHX plugs. That's where I left off. I've followed all wires, electrical, hoses, no tears anywhere, rips, everything has solid connection that I can visibly see.
The engine kicked over, started, ran about 5 seconds, then shut off. A few things I noticed.
1. During that 5 second tenure, no water came out of the 2 holes. (muffins hooked up, assured water was getting through) I don't know if that was to short for it to circulate through?
2. The bottom of the motor, where prop sits, right above it looks funky.. and by funky it doesn't look right.. I snapped pictures, it looks as whatever sat there is partially broke(shark fin looking maybe?), but besides that, its dripping oil. It only started doing this when I attempted to repeat start, and continued after I was done, which was about 6 retries then I stopped. This may be obvious for most of you, but new boater here.. Any helpful tips would be great.
3. Where do I go from here..
Thanks,
Mike
Thanks,
Mike
