74imperialV173
- Aug 16, 2013
- 5
1975 75 hp Chrysler O/B Model 757HA, in the water have problems with the motor kicking hard into transom and then bouncing up and down after engaging the throttle forward. Once the motor seemed to lock into gear the boat will begin to move forward. It actually cracked my transom (which I now suspect was rotten to begin with). Does any one have any suggestions on what this could be and where I should start to fix the issue? I'm new to the boating world so not sure where to start. Thanks.
