I checked compression with all plugs out and hot battery. #1-94psi, #2-92psi, #3-95psi, #4-100psi. I know this is not the greatest compression, but will this engine still run in the water with these results??? It doesn't want to run in the water and of coarse it runs on the hose. It starts and runs in the water for about 30-60 seconds and then dies and gets harder to start the more I try.
