I know I should buy a manual for this thing, but I'd like to snatch the powerhead off right now, and not have to wait for a manual to get here. Not to mention I'm not sure at this point that I even want to invest much more in this motor. I've had prop shaft issues which I'll start a new thread about, but right now I have different issue. The motor has been running rough the last couple of times out. Hard to start, and idling rough, etc. Felt like it was running on 2 cylinders at low rpms. Brought it home a couple of days ago, and ran a compression check. Number 2 cylinder dead (30psi)...... Pulled the head yesterday and found that the number 2 piston is messed up at the exhaust port. Looks like maybe something went through the carb?? Can anyone tell me exactly which bolts need to be removed to take the powerhead off so I can split this thing and get the piston/rod out and see if there's any other damage? At this point I believe I may be able to just hone the cylinder and slap a new piston and rings in it.
