Just replaced the starter on my 1989 85 HO Force with an $80 one from Taiwan that I got via Amazon. Was a bit of a chore since the new starter had nuts on the mounting screws that had to be removed in order to get it to fit correctly. When I removed the nuts the thing tried to come apart. I managed to keep it together and install the thing. The motor starts right up but the star wheel disengages from the flywheel rather quickly on those few times when it doesn't start right away. Is this normal or should I send it back? The old starter (original) would run quite a while before disengaging. I'm new to electric start outboards so don't have any experience to go by. (My last outboard was a pull start 35 HP Evinrude of 1960's vintage.)
Also what lube (if any) should I use on the star wheel teeth?
