Re: Force Side Mount Remote Control Parts
The "aluminum plate" that the plastic "Clutch Gear" mounts onto has four neutral detents 90 degrees apart. The "Clutch Gear" has one neutral detent and three fillers positioned 90, 180 & 270 degrees from the neutral detent. It appears that the control assembly can be mounted so the control cables can exit aft (my configuration), down, forward & up. The "Clutch Gear" can then be positioned with the neutral detent positioned up and the throttle leaver positioned up while in neutral.
In the situation that I had, the filler on the "clutch gear" that is positioned 90 degrees forward of neutral position was broken and missing. Because of that the throttle leaver's "spring loaded" neutral pin would drop into the detent on the "aluminum plate". The PVC fitting that I cut and placed in the "aluminum plate" filled that detent position.
Now the throttle leaver's spring "loaded neutral" pin does not drop into the detent at WOT.
