Hi, for the sake of the reader, I will try to make this Long Story as short as possible. Any Help would be greatly appreciated.
My Force 120 hp 1994 overheated on the way back in.
Tried to start the boat and it seemed as though the battery was weak, I say this because the starter just would not go fast or spin completely.
So, Did the following with no real positive results:
First, tested battery had 11.9 amps
cleaned all terminals and ran continuity from cable to cable. Checked Fine
Checked all starter related connections, checked fine
Replaced starter cables anyway (Because I just love wasting my time and money)
Replaced Starter Relay (Same as Above)
Pulled starter brought it to rebuilder and he said "It's Fine" Not the starter.
Pulled all plugs and starter spins like it should
Flywheel spins great with no friction at top dead center when plugs are out.
Dropped lower unit to change water pump and left it off, just in case it was somehow binding (I Know I'm Reaching)
Disconnected battery cables from starter, attempted to run starter with fully charged power pack, same results
Ran positive cable direct to starter, just tapping to engage, bypassing relays, Same Results
Am now completely baffled. Please Help!
P.S. I posted this in another forum and could not find it, so If you saw it there and answered with some advice, forgive me and post it here again.
Thanks for your help!
P.S. When we pulled the head gasket found a tiny scratch in cyl #3 Had compression on all 3 Cyls, three being slightly lower.
