Hi All,
First off great site. Read almost every post from recents to get up to speed with my new boat.
The problem: Found water in my LU, read all these helpful posts, had new seals installed. At that time my mechanic said that there was some wear on my drive shaft. Once the new seals were installed he did 15psi positive and negative pressure test and found them to hold. Took the boat for a 3 hour spin on the lake with lots of WOT and parked it over night. Checked the oil and found pretty blue clear fluid. Not a drop of water. Happy days. Went back out later and found oil leaking from the top of the lower leg.
The complication: When I picked up the boat from my mechanic I found the plate behind the prop installed upside down. He had his crew fix it immediately. Re-tested it under pressure and I was told it was fine. 15 psi.
My question is: If the seals were done properly, wear found on the drive shaft, can you STILL have oil from the lower leg bolting area? I assumed there was a gasket there. I really dont want to rant at a mechanic but I feel this should have been resolved.
Thank you in advance.
