Ok here is the deal, got a 79 Chrysler HP motor, I watched the video about syncing the carbs and checking the timing but he doesn't go into detail on how to change the timing. I can get the motor on TDC and the curved line on the distributer is 4 teeth away from the line on the fly wheel. I've turn the timing screw to get it that close and have learned that you only have to turn it in very small increments. So how can I get it to line up? Do you rotate the engine more than once or should they line up on every revolution. All plugs are getting spark.
I got the engine to start and run but didn't have the water muffs on correctly and it got hot and died, then it wouldn't start but turns over. I am letting it sit overnight and will try again in the morning. While it was running it sounded like it was missing and backfired through the exhaust when backing off the throttle. The previous owner had the fuel pump rebuilt, compression tested (150 each cylinder), carbs cleaned and rebuilt, lower unit oil changed and all new fuel lines replaced. I replaced the bulb cause it looked old and put a new starting battery (old one only had 135 cranking amps). When I bought it the guy said it ran fine last year and he parked it and it wouldn't start this year. I drained the fuel even though he did use marine grade Stabil in the gas. I drained the fuel from the carb too and replaced with new. Model # 757H9E. Can someone help me please, boating season is almost over and would love to get on the water this weekend.
