Re: 1989 force 125hp, is something missing?
No Force engine ever had a distributor, so it is a Chrysler block. Since it is distributor ignition and since Chrysler went to Prestolite ignition in 1979, that block is earlier than 1979. If the distributor is electronic eye, then the engine block is about 1976-78. Electric eye distributors have two wires: A blue one and a white with black tracer. If it is points inside the distributor, then it is pre-1976. Points distributors only have the white with black tracer.
70 and 90 horsepower were relatively uncommon so the block itself is most likely either 75 or 85. If you have any way to look into exhaust ports, the 75 had circular exhaust ports while the 85 had elongated ones. Exhaust ports are visible if the side cover is removed--not recommended because gaskets will be destroyed and you may snap more than one cover bolts. You can also remove the head. However, if you have a small inspection light you might be able to see through the plug holes. Also, check one of the carbs. 75 and smaller had a 1 3/16 venturi while the 85 and 90 had a 1 5/16 venturi. The venturi size is cast into the carb inside, under the float. IF you have the carb number stamped on the mounting flange, then that also describes the engine size as different carbs were used for different horsepower engines. I don't know them offhand, but if your library has an Intertech manual, ALL carbs ever used are listed in it.
I would not be surprised if someone here has this listing so try replying with the carb number ( example: WB25A, WB1A, WB 19 etc.)
I have this list, but it is in a "safe" place and probably would take me a week to find it. LOL
The pipe plug can be found at Lowes, Home Depot, Sears, plumbing supply stores, or Fastenal.
The US Marine controls will work. In fact any Chrysler or Force control box that is NOT Mercury will work. Most Force parts except ignition and flywheel will fit this engine block.
I can not clearly see the ignition module but it is definitely not the stock Motorola Magna-Power ignition. It may be an aftermarket OR it may be a different module that Chrysler did use on some engines.
