Hi Guys,
I have a 1997 Force 120 that is racing at idle. I ran it a few times in the beginning of the year with no issues. After July 4th I wasn't able to use it for a month until last weekend. I started it up on muffs and it ran good just high rpms at idle. Didn't think much about it. Took it to the lake ran it for a good for a bit pulling a tube no problems. Went out today to start on miffs once again and the idle is still very high. It used to idle at 1200 rpm on muffs. Now it is racing at about 2000 rpms. I tried to do a de-carb today as I though maybe on of the carburetors got gummed up after sitting for a month. No luck still racing at about 2000 rpms. I dont think the idle screw has moved but cant seem to figure this out. Any help would be much appreciated.
Thanks,
Kevin
Thanks,
Kevin
