Like the title says i have a 91 90hp force motor that wont stay running. The problem all started when we were out on the lake and we ran out of gas in the one tank so i switched to the other tank, as soon as i did that it would start for a few seconds then stall out over and over again. We got towed back to shore and headed home. When i got home i hooked up the water muffs and it started up fine, i revved it up and all seemed well. I went to another lake and it was exactly the same, run for a few seconds and die.
I was unaware that i was supposed to run the motor with the vent open and i havent had a chance to test that out yet but i wondering if i may have damaged something running like that? I pulled the fuel pump and the diaphragm doesnt appear to be damaged and builds pressure.
Any help would be appreciated cause im stumped
