Does the black little rectifier hooked to stator only convert ac to dc for battery charging, or does it also affect the firing of plugs. I am chasing a gremlin where 3 & 4 were not firing. Took it to boat shoap who tested everything, stator, coil packs, modulators. Said modulator was problem and I changed it, didn't fix it. I switched the 2 sets of wires from stator (blue/yellow wires) that go to modulators and spark moved from 1, 2 to 3,4. to me which means modulator wasn't bad, but part of stator. changed stator, got firing back and now it has done it again. I have swapped out both modulators, coil packs are good according to shop. The parts were from a force that was running when 2 pistons went south. The only thing is either that black rectifier that my farther in law had changed before I started on it, or the adjustable timing ring under flywheel is the problem. Thank you for your help.
