Hi Everyone, I am helping my neighbor out on his Little 20hp outboard. The model is 204HD, serial is 1318, I think its a 1972 by the charts that I have been looking at. The motor had been in storage for quite some time when he purchased it. We cleaned the carb really well and got it running great on the stand. The problem is that when you take it out on the lake and run full throttle for very long the fuel pump doesnt seem to be pumping enough fuel and allows fuel to drain back into the tank. Here is a list of what we have done and checked:
Fuel hose connections (bypassed by installing barb fittings)
Fuel Primer bulb (verified direction and changed out with a new one due to cracks)
Fuel tank (Connected a different one with completely different hoses)
Fuel Pump (Purchased a rebuild kit, replacing gaskets and diaphragm)
Fuel pump (changed out with a spare)
Checked engine compression (118# on #1 and 120# on #2)
Replaced all fuel lines
The engine runs great when it gets fuel. If you hand pump the primer bulb the carb bowl stays full and the engine runs great.
One thing I noticed that I thought was odd... Both the fuel pumps we had have no spring inside them on the diaphragm. I dont see one on the parts diagram either. Is this a common thing on Chryslers to not have a spring?
Any help would be great. I need a new direction to try to go. The only other thing I can think of to do is hook in a gravity feed system and slowly work my way back towards the tank looking for something but at this point I think it almost has to be something with the pump.
