G
Guest
Guest
help please: I went out today and at full throttle my inflatable boat barely moved (about 2 mph for 5 min then stopped pushing me completely) Prop looks fine, In neutral it spins and very hard to spin in gear ??? wtf is going on??
Bought the engine from some dude1 month ago and only seen it run on neutral. took it to a marina for a tune up and paid extra for them to run it and see if it needs anything. guy ran it and said it ran good. I don't even know If he tested it. changed the impeller based on the video I saw on you tube and wondering could I have screwed something up or it has been like that?? The shift lever was loose from day one if this mean something. I also seen it die couple times when I try to put in fwd. I tried putting In reverse and the ob kicked up and shut off.
