Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
need force part number fk721706
This topic is closed.
  • need force part number fk721706
    Guys im stuck hear. I need fk721706 bad. I cannot find it anywhere. My boat is in the shop and the only thing to guy can do is try to rtv the seal. Im not happy with that fix and need this part. Where can I find it please help...
    Re: need force part number fk721706
    Bit better description? Like the name? Year etc?
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    88 Bayliner 21CC 2001 Mercury 225 HP EFI
    • #3
      That's the replacement top plate kit on the gear case to retrofit the bellows type shift rod seal. It gets rid of the bellows type seal and uses the regular type shift rod seal that you normally see. I thought I saw one site that had them. I'll see if I can find it.
      Try getting in touch with these guys.
      www.franzmarine.com
      Don't know if something like this would work.
      Waterproof Push Rod Seals Rubber Bellow with aluminum mount for rc boat - 2pcs on eBay!
      • #4
        Try Mercury parts.
        • #5
          its for my force 85hp. its to nla part that everyone needs its the gear cover seal. fk721706.. There was a guy that a name here that just went through this rust something or other.. but he said he found a place that had them and was all set but he never once said where. I pm him and every thing. but no response.. I need a fix asap. its at the shop now and the guy is just rtving it back together and said just run it... but the gear case is only holding 5psi.. I would rather fix it right...
          • #6
            franz don't have it anymore and said good luck... I can not belive that this part is used on motor up to 1995. but now is no longer available.. I would be mad as hell if I owned a 95 motor and couldn't get an important part.. That's awfull new to stop making parts for...
            • #7
              mercury no longer makes this part
              • #8
                I would try Mastertech Marine in Florida... these guys seem to have sources for Force parts located all over the country.
                you can email them at mtech at mastertechmarine.com
                They have an online catalog but it's not too easy to navigate.
                steve
                • #9
                  im waiting on a response form the mastertech.. I wounder if the shaft seal can be r/r?? The guy working on my motor now says that it cant be and I have to replace the whole part..
                  • #10
                    If the original seal has a tear, it's usually not repairable. If you could find a rubber bellow seal that was for some other application that has the right dimensions, you could probably use it. Problem is that it may be a lot of trial and error, and cost.
                    • #11
                      no no I found a thread here where a lady named karla was going through the same thing. She hammered out the drive shaft seal and installed new ones. the guy fixing my boat said the seal is not replaceable and I had to replace the whole part... FK721706
                      http://www.mercruiserparts.com/Show_...c=GEAR+HOUSING
                      see if that link works.. It shows all the seals.. so what is my mechanic talking about?
                      • #12
                        This day wont get over soon enough.. wish it wasn't sunday
                        • #13
                          I owed my mechanic an apology. It wasn't the driveshaft seal which is replaceable it is the older style plate that has the bellows. Its the shift shaft that is leaking. So I do need a new plate cover or find some how an obsolete style bellow...Carl
                          • #14
                            I'm running into the same problem on a lower unit repair. Did you ever find a fix?
                            • #15
                              This thread is over 4 years old and the OP has not returned so he won't be answering the phone.
                              Closed.
                              BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
                              Please, no PM's (Private Messages) regarding boat/engine problems.
                              That is what the forums are for.
                              Only forum/moderator issues will be answered in PM's.
