floatfisher
- Jul 2, 2013
- 8
Just wondering if anyone can help here a little (you all have helped out a bunch already, sorry for so many questions!!). Well I thought I had a gas delivery problem, and still might. I bought an external tank and new hose filled it with 6gallons and a quart of oil and put it on the boat (I wont go in to detail about the tank leaking all over the truck bed and the boat!!!!). I can now prime the bulb and seems like there is gas going to the motor (I pulled the plugs and they are wet). Now I try and start the motor and it seems like the battery is dead or almost dead. Tried charging it but the motor tries to turn but very slowly. I hooked the jumper cables up to the truck and to the battery and still the same?!?!
Gas issue, not sure?
Battery issue, not sure now?
One thing I did notice was the starter would pop up to start the motor and not always drop back down when the key was disengaged. The last time I tried to start the motor the starter stayed up and when I took a little pressure off of it from the fly wheel it dropped back down?!!?
Starter issue??
I am going camping with the family in 2 weeks and we are supposed to take the boat to Sampson for a few days. I would really like to have this issue fixed and be able to sue the boat with out being too worried about getting stranded on the lake!!
Thinking I should try and find a mechanic and try and get it fixed, if that can happen it 2 weeks!!! Any help would be greatly appreciated!!!
Thanks,
Mike
Starter issue??
Thanks,
Mike
