bassboy416
- Jul 9, 2013
- 79
Hey,
So I recently took out a boat I just purchased for the first time. I noticed a few things about it and am not sure if they are interconnected or not but my main question is why is it when I checked the 4 spark plugs that the upper two were white and the bottom two looked pretty normal???? It looks as if there are 2 carbs and 1 is for the top 2 cylinders and 1 is for the bottom but im not sure. So, heres some symptoms. The boat ran great at higher speeds and once warm ran better than before, but it seemed to have a high idle in nuetral. It would rev a little higher than I'm used to out of gear but once put in gear it would often times die. If you put it into gear hard it would run just fine and go like crazy. It ran very well, and I was able to easily get it on plane, but white spark plugs tell me that something is getting hot. Before I cause damage, I'd like to find out if anyone has ever seen something like this before. Why are only two spark plugs running hot?
Jimmy
Jimmy
