Dear all
Would you be able to help?
I have 1989 Bayliner 1950 with Force 125 outboard (1251x9B). I have had it 2 years and never got it run well.
Motor starts up and idles well but gives only 2600 rpm when putting full throttle forward. After minute or two it planes and can get it to 3500 rpm when trim all up. When putting it in reverse it gives easily 4000 rpm and over.
I had it looked over in a shop and they found compression all good and also cleaned the carbs. They changed the CDI boxes but none of this helped.
I rebuild the fuel pump and tested with external gas tank without success.
Appreciate all help and ideas!
