1987force50
- Jul 5, 2013
- 3
Hello, I have a 1987 force 50 hp lower unit problem. Just installed another front gear because the last one had two teeth busted off. No problem with seals and no water in lower unit. Installed new front gear. Took it out last weekend and ran fine on the way out. Started the trip back and at half throttle popped back out of gear. Can run at 8-10 mph only. Faster than that it kicks out of gear. One thing I did notice. The top pinion gear race just sits on top of bearing and is not pressed in. ??? Verified prop is not slipping. Any ideal whats causing this. I appreciate your help. Thanks
