This is my maiden voyage on this site.
I have purchased my first boat that also came with my first outboard motor. The boat is a 1963 MFG Niagara Runabout and the motor is a 50 HP US Marine Force. I am aware that neither of these are quality items but I did pick them up with a trailer for $350.00.
Now on to my question. I put the motor in a tub making sure that the inlets were covered and started the motor. I had changed the plugs just prior and the motor started up after a few cranks. It ran for a bit (rough as it was) and then stalled. As it was running, I checked to see if water was coming out of the discharges and there was none. I believe that the motor was under the water far enough since it was just over the planer fins. does this mean that I have a water pump issue? I have researched on line and see quite a few listings for changing the impeller. Is this the likely reason for the stalling and hot motor? Does changing the impeller usually do the trick if it is the problem or is there a complete rebuild of the water pump that is in my future?
Thank you for any help that you folks can offer.
