I have a 1996 Force 120. I start the engine it runs great about 2 minutes and then it dies. But when I noticed that the engine is dying if I pump the bulb manually it go on without problems. I have changed fuel pump gaskets but in the kit there are no rubber check valve, only plastic gasket. See attached pics. Somebody knows if this gasket kit is ok?
