Sloppy78
- Jul 2, 2013
- 46
I have a 1988 Bayliner trophy Bass boat with a 85 hp force engine on it. I am having two problems with my boat And any help would be appreciated.
1) I bought a new overheat sensor and buzzer and it is still not working after I installed it. I read that when you turn the key to start the engine the buzzer should sound a few seconds to test its working. I hear nothing. What else can it be? I've checked my connections and seem correct but I'm not too good with electrical. Any ideas?
2) The book has been sitting for about two years unran. I brought it into the mechanic and had the water pump replaced and everything checked out. He put a marine stabilizer into the gas tank to clean out the engine and not Only does it smoke a lot but it will not stay running in idle even after being run for an hour straight. Is there anything else I can do so it won't die out all the time ? Thanks so much.
