Re: 1998 mercury force 120 RUNNING HOT?
The water should be warm.
The water pump,anything been done there?
Change the impeller,check for excessive wear on the stainless plate and the stainless cup.
You need to see if it still has the thermostat?
Also test the overheat system.
