I was at the lake today fishing when I noticed my 1997 force 50HP volt gauge was pegged at 18v. If I idled it down it would drop to 14v. My depth finder said input voltage to high. So I came home and started trouble hooting the motor. started off by checking the voltage regulator, cant see any issues with it. so I was about to give up and take it to a mechanic, but I decided to switch the battery leads over to my trolling motor battery. Well when I did that the volt gauge started reading back to normal even when I idled it up it wouldn't go over 14v. I thought bad battery, I took it down to the automotive store to see if it was the battery and they said the battery is good. I'm stumped. Why does it do it on my cranking battery but not my trolling motor battery? Please help, not sure if I need to by a regulator or a new battery.
