Re: 1989 85hp Force charging question.
Sounds pretty normal to me considering there is no regulator on these units. Anyways, try verifying the input voltage from the rectifier to see if it is also spiking. Make sure you are reading directly from the rectifier and not from an installed voltmeter.
