first off all im sorry if i ask a dump questions but this is the first time to deal with marine motors
ok here my story with 1990 force 90 hp flywheel
i think i did everything to remove this flywheel with no success. took nut off and put it back on with couple turns then level up all three screws then tight up the puller screw real good hit it with my Hammer couple times nothing happen . took the whole power head to the shop they tried heavy duty tools to get it off with no success .i put the 3 screws and the puller screw back tight them again and sprayed it wd 40 left it over night then start hit the puller screw again with hammer with no result then i bought impact wrench tried it then one of the 3 screw come off now the hole needs to be re thread again . so i think i tried everything possible ,so please if you have any idea what i should do with it now please help
i have another question is the flywheel has to be in Specified position or something and is there is anything i need to take off beside the top nut coz i feel that there is something holding the flywheel underneath is there is a key or something please help
