Re: 1975 Chrysler 20hp Lower Unit Oil Seal problem
ok i found the problem with the drive shaft oil seal under the water pump. When i was replacing all my oil seals i had all the parts, new oil seals, layed out on work bench. As i was replacing them one by one i didn't notice that i used the wrong oil seal, i used my extra prop shaft seal for the drive shaft, the prop seal was bigger i checked it with a guage not by much. So pulled out the wrong seal and used the EXTRA one i didn't know where came from. Put the extra one in, filled LU with oil, put back on motor, put in water and ran it for 5 minutes soild, stopped and checked the oil. NO water was in LU not even a drop. The oil had the little bubbles in it from checking it right after i ran it but no water- oil was ok. So lessons learned is that to always check your parts, list them, work by doing one task at a time, remove old parts from your work bench and maybe you won't have a situation like mine.
