I removed my lower unit to replace the water pump and I let the boat sit over night with the lower unit off. when I went out in the morning I had a small patch of oil under the motor. Since the lower unit was off I thought nothing of it. Put the new pump and and bolted her back together came out the next day and another small patch of oil on the ground. I found this awkward because my force takes pre mixed gas so idk where this oil is coming from any ideas on where this could be coming from and should I be worried?
1992 force 120hp 1208x92C
