notsunkyet
- Jun 8, 2009
- 198
ok so took the bayliner out this year and all seemed well, got half way across the lake and stopped to play.... tried to restart engine had a difficult time of getting her to fire up... then it would idle for a second then go thump (like a misfire idle misfire idle etc) a few time try to idle then thump again... tried to wot and it almost flat died! limped it across the lake at just above idle, with no power at all.... took 2 hrs to go .25mi. got home and checked plugs all seemed ok replaced anyway... then tried to start and hard starting again.... got her to run but it did the same thing as on the lake.
took comp test best I got was 90psi... I think I did hear the over heat alarm chime at the lake and it took forever to get water out of my telltail.... should almost be instant but took like 15=20 seconds... so im thinking I blew the head gasket or worse....and the impeller is going to get a new one
help guys help!
help guys help!
