Hello - I've pulled our pontoon w/ a 1997 Force 90 s-stroke out of the water for maintenance; I'm generally fairly handy but have never replaced an impeller, I've searched and watched a few You-Tubes but still have a question or two.
- Shift Linkage: Our appears to be some type of spline connection and have heard different thoughts. Best to shift into forward or leave in neutral before dropping the lower unit?
- Grease: I've seen the suggestion of applying a light coat of grease to the impeller to aid the initial dry start-up - marine wheel bearing grease ok? Other?
- Anyone have pics or diagrams regarding the shift linkage for a better feel of what to expect?
Pic of shift linkage attached.
Thanks,
Steve
Thanks,
Steve
