Hello all! I recently scored a FREE 14ft fiberglass hull with a trailer and a new floor and solid transom. All of the wiring is in place as are the fuel and control lines. The outboard on the back of this is a 1966 Chrysler 45HP Model 45631, Serial 3251 it looks like a long shaft. The upper motor and the powerhead appear to be in very good condition however the lower unit needs some attention. The friend I got it from threw a prop a few months ago, the driveshaft is intact and fine but it looks like I need to replace the lower drive gears and reverse, as well as the bevel gear and the driveshaft bearing, the propshaft and the prop as well. I have read that the lower unit parts on these motors is interchangeable with other motors in the 35-55 hp range, is this true? I am trying to figure out where I can find these parts, I have found some on Ebay but want to make sure I have the right stuff before I order it. I am a NEWB when it comes to boat motors but not to fixing other motors and other mechanical stuff.
Any advice to point me in the right direction as to parts interchangeability or maybe any parts I am leaving out is greatly appreciated.
Thanks in advance,
Ryan.
Thanks in advance,
Ryan.
