myerchinize
- Jun 7, 2013
- 6
Hey guys! I've been reading thru the forum looking for help and decided to post my own. I have 1982 Chrysler 125hp model # 1258H2B. I had the motor running. It was boggy and backfiring. Noticed gas leaking out of lower carb. Here comes the fun stuff... Got a new float online. Couldn't find a needle and seat. Ended up finding an old forum with help. Said to use a briggs and stratton part #. Worked great. Carb doesn't leak. Pump the bulb, gets rock hard. Sweet! Turn it over, and now I managed to lose spark to all 4 cyls. No clue where to go from here. Tried wiggling all the wires around as I didn't touch the wiring for a carb change. Tried getting the flywheel off to look underneath for loose/broken wires. Won't budge with a puller and impact wrench. Looking for help on what to check and how to check it. Had a guy tell me to look for a loose magnet under the flywheel. Still trying to get it off to look. I just don't understand, I had it running before the carb work and now nothing. Thank you for your time. -Jason
