Re: 1986 Force 125 throttle shift cable install/adjust help
The very firs post is a tutorial video on setting timing and carbs. At the end I believe I show the throttle and shift cables.
At any rate, at the engine end, you clip the groove of the throttle cable into the fitting at the bottom of the timing tower and snug the screw down. You clip the groove of the shift cable into the fitting on the shift arm. For ease, You advance the control handle a bit and clip the quick-connects over the ball ends.
Adjust the large throttle quick-connect by threading it on or off the end of the control cable. Adjust it so that in neutral there is about 1/4 inch of the center spring loaded part pulled out. This ensures that the idle stop screw will seat firmly against the block at idle.
