Eddie Rivera
- Feb 19, 2013
- 183
look at the picture with the red mark - am i missing a cap??
89 Force 50 HP wastes too much fuel and I increase the throttle it squirts fuel from end at bottom- where the carb meets the block. Also at high speeds it squirts from the small plugs and leaks out a lot from the lower bowl and it bogs out at high revolutions.
I have the new gasket kit with 3 gaskets. one for the bowl and two little ones. I have the gasket for the area where the carb meets the block also I got a new floater. I've never worked carbs and I'm intimidated.
Please advise! On procedures or what to watch out for or anything else. Thank you
