I recently bought a 14 foot fibreglass powerboat, the price was right, it looked pretty clean, the guy hooked water up to it and showed me it working, it started great and idles nice, however I noticed that the prop wasn't fully spinning, since I wasn't on the controls I didn't think much of it, brought it home cleaned it up. Took it out on the lake the next day and fired it up and the engine would rev but the boat would not go anywhere, much like an old Chrysler mini van the missus used to have it did manage to "slip" into reverse for a few minutes but that was it. So I fired up the electric trolling motor and brought it back in. I have done extensive searching online and have come up with a couple suggestions of checking the shear pin and the splines on the prop, both are fine, and checking the shift linkage which seems a bit off however I can put it in neutral and spin the prop both ways as well as forward and reverse and only be able to spin the prop one way and have resistance the other. The major problem is that in small town prairie Alberta there are zero boat mechanics to ask for advice or help, I am mechanically apt and more than capable, I just need to know where to start or of this is common and some suggestions to get this thing back in the water so the kids and I can enjoy it as intended. Thanks in advance.
