Well I am having to manually shift my motor due to the bracket that transfers the shifter cable movement into a downward motion to move the shift rod. The bracket is the one that strikes the limit switch for neutral safety switch. ANyways the bracket is wallowed out and so half of the cable movement is spent taking up slack on the bracket. To add to the issue someone has welded the bolt/mount screw that holds this bracket so I'm not sure I can remove it easily. Here is my question does the bracket have a larger hole that rides on a bolt with an enlarged shoulder or ridge thus allowing it to tighten down fully to the step and not against the bracket? I think thats how my old 90 hp was but am not sure. I need to figure out away to shore this bracket up or else its manually shifting from here out for me. Thanks Mitch
Anyone with a good picture of a non welded bolt on motor would be great. I don't have schematics to locate this part.
