ima.riverrat
- Oct 9, 2012
- 9
I have a quick question I hope someone can answer. I have a Force '89 85 hp and a Force '86 125 hp. the power head on the 125 is bad and the lower unit on the 85 is bad.
Now my question is will the gear difference be ok for this swap, to put the 125 lower end onto the 85 power head? they have the same shaft length so it would be a direct swap.
Also, The same size prop is on both motors now... should I change?
Thanks for any help
Rich.
Livin' in a Van down by the River
Thanks for any help
Rich.
