Fallibleshrimp
- May 20, 2013
- 1
Hey all. My roommate has an 89' Thunder Craft with a US Force 90 HP motor on it. The Tilt/Trim hydraulic system is leaking. The assembly has 2 hydraulic pistons, connected to a horizontal bolt. The leak is coming from the line going right behind said bolt fascia. Was curious, do we just take that bolt off, and the whole piece comes off? Can anyone give some advice on how to remove it without removing the entire motor? Thanks!
