Eddie Rivera
- Feb 19, 2013
- 183
1989 force 50 hp : Squirts fuel at high idles and when brought back to neutral it shakes and shuts off.
After it shuts off i try to re start it and after several tries there is a fuse (15) that burns under the helms control panel.
Carburetor has been adjusted to specks - close all the way and bring back one full turn.
After i adjusted the motor shakes and dies when i put the motor cover on it.
I eventually adjusted one full turn back minus just a bit so it could idle a bit faster and then when i put the cover it stayed a bit shaky but ok.
My question is- is it normal for the carb to squirt fuel from the lower back and from the side little pin heads and from the bottom of the front of the carb at the little fuel holder thing?
The plunger seems to build a bit of a film around the little plunger it self - is that normal?
The little metal hose clamps keep coming lose - can i or should i use lock tight on it?
Please let me know if i should just rebuild the carb and ho to do it and how to order the kit and what comes on the kit???
