Hi fellows, I'm a entusiast fisherman and use a 1974 55 Hp Chrysler engine.
Got a cooling problem and need your kindly support!!!!!
Not enough water is being circulated in the system and the witness in the engine exhaust spitting poor water. Engine has no thermostat as it does not need it, the climate is always mild and is used in fresh water.
I already change the impeller, new head gasket (bolts torque at 28 lbs with locktite), new gasket for lower unit, new water pump gasket and new hose (from exhaust to head).
I down the lower unit and put the garden hose in to the copper tube, passed water to ensure the system is not blocked. The water flows nice, no problem.... then????? :facepalm:
Any suggestions?
Any suggestions?
