newpontoonie
- Apr 21, 2013
- 7
I just replace the water pump on my 1988 force 50 hp and I put the water muffs on it turn on the hose and I can't tell if water is actually pumping or not. This is a new motor to me and I have limited experience with outboards. Does the water actually spit out the exhaust or the lower unit. Is it possible I installed the impeller backwards meaning the splines or finger are bent in the wrong position?
